ONTAP Hardware
Looking for standalone Filer.
rajivg
Can somebody shar a standalone filer for a day? I will need to run some test using that filer.  Filer configuration will be untouched, I will have to run config advisor from remote machine to collect data.
3 REPLIES 3
reinoud7
If I understand you correctly, you need physical access between your application server and the filer? It's not a script that some else can run?
Reinoud
rajivg
I will need only network connectivity to the standalone filer. SAN Config Advisor uses ontapi (Zapi) to collect data from the filer.
reinoud7
Can the simulator helps you? I have a test/play filer, but it's very difficult to give you an other access than ssh to the console. You can also ask your account manager to help.
