ONTAP Hardware
MDIO read failed in t3_link_fault
ACHOU_SIMG
Hi,
My FAS8040 running 8.1.4P7 outputs the following error non-stop after logging in to the console.
I have not found much information about exactly what is wrong.
Does anyone know what exactly is the problem? Is it parts on the motherboard failing? Basically I am trying to find out whether the fault is on the motherboard itself or something external.
thanks,
1 ACCEPTED SOLUTION
hariprak
Hi,
The t3_link_fault is the onboard adapter bound to a faulty chip. This means the MotherBoard is likely just faulty and needs replacing.
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
1 REPLY 1
hariprak
Hi,
Thanks
