ONTAP Hardware
Material Safety Data Sheet Question
NAShip20
Good Afternoon! I know this is an odd question, but has anyone ever requested a material safety data sheet from NetApp?  We purchased a refurbished NVRAM battery (271-00024) that we need to ship overseas  but in order for our warehouse to ship this item, they will need this document present.  We have an old FAS2040 device out of warranty that we are needing to replace the battery on.  I have looked all over NetApp's support website and via an internet search without luck.  Just thought I try to ask here.  Thanks!
1 ACCEPTED SOLUTION
darb0505
Hi NAShip20,
I was able to locate the MSDS for the NVRAM battery part 271-00024.  I have attached it to this posting for your reference.
Let me know if you have any additional questions.
Thanks
Team NetApp
3 REPLIES 3
darb0505
Hi NAShip20,
I am looking into your question on the MSDS for the NVRAM battery (271-00024).   I will get back in touch with you once I have some more information.
Thanks
Team NetApp
NAShip20
Thank you darb!
darb0505
Hi NAShip20,
Thanks
Team NetApp
