ONTAP Hardware
Maximum and Minimum limits on netapp storage
GUVNIJJAR
can someone give me a link where there are listing of all maximums and minimums of settings you have on a netapp storage system , like max aggr, max volumes, max snapshot, max disks in a raid, max lun etc.........
Also can you assist with the below queries:
how many luns can you have on a volume
whats the max size of a lun on a volume
how many volumes can u have on an aggregate
how many snapshot copies can you have on a volume and aggregate.
Any advise please
2 REPLIES 2
AGUMADAVALLI
it all depends on the data ontap version and fas system you have. Please refer to the storage resilency document of FAS series you have.
thank you,
Ak G
aborzenkov
Most limits are listed in Storage Management Guide. The only minimum limits I am aware of are
- You need at least 2 disks to build an aggregate
- There is minimum root volume size which is model dependent
- Flexvol cannot be smaller than approximately 20MB
