ONTAP Hardware
Mixing two diffrent SAS disk shelves in same stack
sahan_ml
Hi All,
I have a FAS8020 9.0 cDOT dual controller (HA) in same chassis. Only two onboard SAS ports (0a and 0b) available.
I want to connect following disk shelves within only one stack since I don't have additional SAS cards available.
- One DS4246 IOM6 24x SATA 2TB
- Four DS2246 IOM6 24x SAS 600 GB 10k
Can I mix above different disk shelves in same stack? Is it a valid configuration?
If yes, Is there performance impact or any issue in the future?
Thank you.
1 REPLY 1
Darkstar
Hi,
yes, this is definitely a supported configuration.
The only shelves which cannot be mixed are 4486 shelves (they can only be on a stack with other 4486 shelves) and the new IOM12 shelves (they cannot mix with either IOM3 and/or IOM6)
For details see the Storage Subsystem Technical FAQ and TR3437 and TR3838
NetApp recommends having as few transitions from SAS<->SATA as possible, for historical reasons, but experience has shown that there is no performance impact for spinning disks, no matter how many transitions you have. Still, I wouldn't put the single SATA shelf in the middle of the stack but rather at one end...
Regards
-Michael
