ONTAP Hardware
NetApp FAS3140 LUN RESIZE, help me please!
LETHANHNHA01
LUN STATUS
fas3140b> df -g
Filesystem               total       used      avail capacity  Mounted on        apshot
/vol/voluat/             400GB      300GB       99GB      75%  /vol/voluat/
/vol/voluat/.snapshot        0GB        0GB        0GB     ---%  /vol/voluat/.sn        apshot
fas3140b> lun show -v
        /vol/voluat/qt1/lunuat     300.0g (322163441664)  (r/w, online, mapped)
                Serial#: W-Q7c4Y9UT5r
                Share: none
                Space Reservation: enabled
                Multiprotocol Type: aix
                Maps: uat_igroup=2
lun is currently empty 300GB 100GB, I would like to increase to 350GB lun
LUN RESIZE STATUS
fas3140b> lun resize /vol/voluat/qt1/lunuat.lun +50g
lun resize: No such LUN exists
fas3140b> lun resize /vol/voluat/qt1/lunuat +50g
lun resize: resized to:  350.1g (375881990144)
successful implementation resize lun
fas3140b> lun show -v /vol/voluat/qt1/lunuat
        /vol/voluat/qt1/lunuat     350.1g (375881990144)  (r/w, online, mapped)
                Share: none
                Maps: uat_igroup=2
fas3140b> df -g
/vol/voluat/             400GB      350GB       49GB      88%  /vol/voluat/
/vol/voluat/.snapshot        0GB        0GB        0GB     ---%  /vol/voluat/.snapshot
But I do not see IBM power capacity to increase hdisk map
[root@uat:/]# lspv -L hdisk2
PHYSICAL VOLUME:    hdisk2                   VOLUME GROUP:     uatdatavg
PV IDENTIFIER:      00c713a535ed94bd VG IDENTIFIER     00c713a500004c000000012a6e893410
PV STATE:           active
STALE PARTITIONS:   0                        ALLOCATABLE:      yes
PP SIZE:            512 megabyte(s)          LOGICAL VOLUMES:  2
TOTAL PPs:          600 (307200 megabytes)   VG DESCRIPTORS:   2
FREE PPs:           0 (0 megabytes)          HOT SPARE:        no
USED PPs:           600 (307200 megabytes)   MAX REQUEST:      256 kilobytes
FREE DISTRIBUTION:  00..00..00..00..00
USED DISTRIBUTION:  120..120..120..120..120
MIRROR POOL:        None
[root@uat:/]# lsvg
rootvg
uatdatavg
[root@uat:/]# lsvg uatdatavg
VOLUME GROUP:       uatdatavg                VG IDENTIFIER:  00c713a500004c000000012a6e893410
VG STATE:           active                   PP SIZE:        512 megabyte(s)
VG PERMISSION:      read/write               TOTAL PPs:      600 (307200 megabytes)
MAX LVs:            512                      FREE PPs:       0 (0 megabytes)
LVs:                2                        USED PPs:       600 (307200 megabytes)
OPEN LVs:           2                        QUORUM:         2 (Enabled)
TOTAL PVs:          1                        VG DESCRIPTORS: 2
STALE PVs:          0                        STALE PPs:      0
ACTIVE PVs:         1                        AUTO ON:        yes
MAX PPs per VG:     130048
MAX PPs per PV:     1016                     MAX PVs:        128
LTG size (Dynamic): 256 kilobyte(s)          AUTO SYNC:      no
HOT SPARE:          no                       BB POLICY:      relocatable
Please help me!
thanks all
3 REPLIES 3
vladimirzhigulin
Hi,
Once you've changed LUN size on storage side, you need to make you host OS aware about that. I'm not familiar with AIX, but here is CentOS / RHEL 5.5 example (assuming that the LUN is known as /dev/sda device on the host):
echo 1 > /sys/block/sda/device/rescan
It will make the host OS aware about the LUN size changed.
Real life configurations are usually more complicated than that and invoke "volume managers", so you'd need to make extra steps to make your volume manager aware about storage side changes.
Vladimir
LETHANHNHA01
I still do not do it, anyone know this problem with help
crocker
This looks like a support related issue.  If this is critical, you should open a case with NetApp Support.  If it is not a critical issue, we have external and internal subject matter experts in the NetApp Support Community answering questions about Filers.  If you have an active NetApp Single Sign On (SSO) account login, this link enables you to engage them about this.
