ONTAP Hardware
NetAppDocs Hardware file
Greg66
Hello,
where can I find the Hardware file for Netappdocs ?
"WARNING: The Hardware-ONTAP file is out of date. An update should be downloaded from the NetAppDocs Communit
y site and copied to the folder: C:\Program Files (x86)\NetApp\NetAppDocs PowerShell Module\NetAppDocs\Resou
rces"
1 ACCEPTED SOLUTION
andris
Great...
This forum posting hosts the latest hardware-ONTAP.xml file.
https://community.netapp.com/t5/NetAppDocs/Hardware-ONTAP-XML-file/m-p/310468
The XML file link there has a date code of: 20230216
4 REPLIES 4
andris
Do you have the latest version (4.0)?
NetAppDocs download: https://mysupport.netapp.com/site/tools/tool-eula/netappdocs
NetAppDocs is supported via the NetAppDocs Community Site or by emailing the following DL: [email protected]
Greg66
yes, I downloaded it today.
andris
Great...
Drew_C
For others who find this thread in the future, I want to make it clear that the link above is only accessible to users with verified NSS partner accounts.
Community Manager \\ NetApp
