ONTAP Hardware
Netapp FAS2554 cabling
netappeng75
Hello
Can someone please confirm that the cabling is documented correctly. We have have two fas2554 controllers positioned at the bottom connecting to two DS424x disk shelves.
1 ACCEPTED SOLUTION
Ontapforrum
Hi,
Cabling looks correct (key rule is: SAS Cabling should follow "Circle to Square").
You can also download "Active IQ Config Advisor" which is a recommended tool to check hardware related correctness and conformance to NetApp recommended settings
Thanks!
2 REPLIES 2
Ontapforrum
Hi,
Thanks!
netappeng75
Thanks you very much for confirming
