ONTAP Hardware
Network Configuration Between FAS3240 and Extreme Networks
cgeck0000
With the ifgrp we're using LACP and IP load balancing for the 2 NIC ports. Over the weekend we lost one of the two switches in the stack. I would expect all traffic to failover to the one switch still up, but this was not the case. Need to know why.
We're using Extreme Summit x450 switches with MLAG setup between the switches.
Can anyone ellaborate on this configuration and if this should work how I expect it?
1 REPLY 1
ERIC_TSYS
Hi,
You d need to provide a lot more info than this for us to help. Have you got diagrams of your config?? Did you look in messages file for error messages?
Eric
