ONTAP Hardware
Old Netapp is Cluster Interconnect Problem
pointshop
I have an older Fas270C in our dev area. What a workhorse, it is still going after 7 years.  We have had a problem come up. The First volume failed and caused us to Force Failover.  We had spares, but I guess there is something special about the very first disk.  New drive in there and it has rebuilt. The device is up and data serving fine.  The parter controller will not come back with: cf giveback.
We also swapped the controller for the parter controller. Just to make sure the partner controller failed.  We checked IPs and both sides' IPs are up and fine. We have iSCSI running over both and data is flowing.
This looks like our main issue: cf.nm.nicReset:warning]: Initiating soft reset on Cluster Interconnect card 0 due to rendezvous jammed
Got any ideas how to diagnose this?
storm2(takeover)> ifconfig -a
e0a: flags=48e8043<UP,BROADCAST,RUNNING,MULTICAST,MULTIHOST,PARTNER_UP,NOWINS> mtu 1500
          inet 10.100.1.51 netmask 0xffffff00 broadcast 10.100.1.255
          partner inet 10.100.1.50 (e0a)
          ether 00:a0:98:03:9d:d5 (auto-1000t-fd-up) flowcontrol full
e0b: flags=48e8043<UP,BROADCAST,RUNNING,MULTICAST,MULTIHOST,PARTNER_UP,NOWINS> mtu 1500
          inet 10.100.0.251 netmask 0xffffff00 broadcast 10.100.0.255
          partner inet 10.100.1.10 (e0b)
          ether 00:a0:98:03:9d:d6 (auto-1000t-fd-up) flowcontrol full
lo: flags=19e8049<UP,LOOPBACK,RUNNING,MULTICAST,MULTIHOST,PARTNER_UP,TCPCKSUM> mtu 8160
          inet 127.0.0.1 netmask 0xff000000 broadcast 127.0.0.1
          ether f0:7b:af:37:04:00 (VIA Provider)
storm2(takeover)> Sat Feb  8 09:44:03 EST [storm2 (takeover): cf.nm.nicReset:warning]: Initiating soft reset on Cluster Interconnect card 0 due to rendezvous jammed
storm2(takeover)> Sat Feb  8 09:46:06 EST [storm2 (takeover): cf.nm.nicReset:warning]: Initiating soft reset on Cluster Interconnect card 0 due to rendezvous jammed
Sat Feb  8 09:47:08 EST [storm2 (takeover): cf.nm.nicReset:warning]: Initiating soft reset on Cluster Interconnect card 0 due to rendezvous jammed
cf monitor
  current time: 08Feb2014 09:40:46
  TAKEOVER 10:44:00, partner 'storm1', cluster monitor enabled
storm2(takeover)> cf giveback
Partner not waiting for giveback, giveback cancelled.
To do a giveback without checking for partner readiness, please either set option "cf.giveback.check.partner" to "off" before doing "cf giveback" again, or do "cf giveback -f".
The first choice disables checking for all future "cf giveback", until it's turned back to "on". The second choice is good for this giveback only.
storm2(takeover)> Sat Feb  8 09:41:59 EST [storm2 (takeover): cf.nm.nicReset:warning]: Initiating soft reset on Cluster Interconnect card 0 due to rendezvous jammed
3 REPLIES 3
jizhengqing
I meet same problem,just like you, do you have resolve this problem.
shane_bradley
I'd check BURT 412390, Fixed in 7.3.4P2 and 7.3.3P5
jizhengqing
Many thanks for your timely help, I've been troubled for a long time for this question,  If do not patch microcode upgrades . It frequently happen?
