ONTAP Hardware
Part Number 8 TB FAS2750
Cornish
Does any one know the part number of the 8TB drives these would b?
25 x disks NL-SAS of a capacity 8TB to the matrix Netapp FAS 2750
Kind Regards,
Ben
1 ACCEPTED SOLUTION
paul_stejskal
There are several. Anything that has HDD, 8.0TB, 7.2k, SAS on the below page is what you want: https://mysupport.netapp.com/site/downloads/firmware/disk-drive-firmware
5 REPLIES 5
paul_stejskal
Cornish
Cornish
Would anyone know what systems would take 25 x disks NL-SAS of a capacity 8TB would it be a FAS or a DS shelf?
Like is FAS2750 the best model for this?
andris
I would suggest you peruse the NetApp Hardware Universe (https://hwu.netapp.com).
8TB NL-SAS drives are large form-factor HDDs. They would only physically fit in the following platforms/shelves:
  • FAS2620, FAS2720
  • DS212C
  • DS460C (only the HDDs that have the carrier for the DS460C's drawer trays).
andris
I meant to add...
FAS2620, FAS2720, DS212C are all 12-drive LFF shelf chassis.
The DS460C is a 60-drive chassis - 5 drawers with 12 x LFF drives, each.
