ONTAP Hardware
Performance comparaison between FAS models
storagedp
Hello,
Is there any document that compare performance between FAS series and models (for example : FAS3xxx / FAS31xx / FAS32xx)
I particulary interrested in comparing performance of a FAS3240 versus a FAS3070
Notice : I do not have access to the "Fields Portal"
Best Regards
4 REPLIES 4
roman_verysell
This info under NDA now.
You can look at SPC-1 and SPEC SFS2008 published results.
radek_kubka
Good question.
For some workloads (not all) 3240 can beat 3170, so my informed guess would be 3070 won't stand a chance against 3240 (the latter has the same amount of RAM, twice as much of NVRAM & definitely faster CPU comparing to the former).
Regards,
Radek
peluso
there is a tech ontap article coming out jan 26th that will cover some of this as well. look for it here http://communities.netapp.com/groups/tech-ontap later this month.
terri
Thanks so much!
Terri Peluso
Senior Community Program Manager
BrendonHiggins
We have both the FAS3070 and FAS3170 and the difference between them is massive.
This graph shows two Exchange 2003 luns.  Aug 2009 was when we moved them from the FAS3070 to the FAS3170.
~  Sorry no image upload.
It would show a drop from 12ms to 2ms.
