ONTAP Hardware
Power FAS2552 and FAS2650
dffas
Can someone tell me the power rating for the FAS2552 and FAS2650?  It isn't on the datasheet where it SHOULD be, and I don't have access to the device software.
Thanks.
1 ACCEPTED SOLUTION
J-L-B
Try under NetApp's online Hardware Universe here  https://hwu.netapp.com
Very easy to use!!
Choose Platforms then choose FAS and choose your OS version.  Then you can choose your models FAS2552 or FAS2650.  Then choose Show Results.  There's an Electrical Requirements section in it which shows the ratings for different controller configurations.
-JLB
1 REPLY 1
J-L-B
Very easy to use!!
-JLB
