ONTAP Hardware
Power consumption per controller FAS2552
ADDEDMARIORF3
Hello Team
I need to know the power consumption of the FAS2552 controller with 24x 1.8T SAS. I am looking in HWU site, FAS2500 datasheet and FAS2550 specs and not see this information.
any ideia?
Thank you.
-MFSP
1 ACCEPTED SOLUTION
xandervanegmond
Hi,
When you go into HWU and select the fas2552 and show results, there is also a link for electrical requirements.
That will show you the various power consumptions depending on single controller, HA pair, 900GB disks, 3.8TB, etc.
That should definitely get you going, I expect.
/Xander
4 REPLIES 4
xandervanegmond
Hi,
/Xander
ADDEDMARIORF3
THANK YOU XANDER.
dffas
I don't have access to HWU, and cant read the image.  It SHOULD be on the datasheet, but it isn't.
AlexDawson
Unfortunately the answer isn't simple enough to just put on a datasheet - for use in commercial datacenters, we find our users need to know exact power draw, which differs based on number of working PSUs, supply voltage and disk and controller configuration.
The FAS2552 depending on configuration, uses between 220W and 500W. We wouldn't want to put "500W" on the spec sheet and have someone to not look at it because they have a 300W limit or comparison figure, when the configuration they're looking at only uses 280W, for example.
Your reseller should be able to supply exact specs for the model and configuration you're looking at, or be working with NetApp channel team to supply those details.
