ONTAP Hardware
Power feed requirements for A900 & NS224
GregR_OT
Hi, I was trying to locate information on the power requirements/typical draw for A900 controller and NS224 disk shelf so I can properly size the power feeds for the entire rack. All I was able to find in the available documentation is the combined power draw for a A900 configured with a single NS224 shelf? I'd really appreciate if anybody out there could share any info.
1 ACCEPTED SOLUTION
SpindleNinja
Have you looked at hwu.netapp.com ? it's all in there.
4 REPLIES 4
SpindleNinja
andris
Yes, I agree. If you go to https://hwu.netapp.com and look up each product, you’ll see quite detailed power specifications.
GregR_OT
thank you @SpindleNinja & @andris for providing this source! Very helpful.
cedric_renauld
And if you're a NetApp Partner's, you can also do it by Fusion web site, it's more accurate, you can spesify the number and disk size to have an exact power consumation
