ONTAP Hardware
Question about backup
YOTAM_A32
hello
i like to know if i can backup NetApp to extanl hard drive
if it can be done what tool should i use to do so
I have FAS960
Thank you
1 REPLY 1
arunchak
What do you mean by NetApp to external hard drive?
Assuming that you have data in NetApp filer volume and you want to copy to your usb drive connected to your laptop. ->
export the volume in the filer (which might have already been done, just check under exports in filer view).
Now map the volume to your windows host -> \\<filer>:\vol\<vol name> (assuming that this is the path of your volume)
Copy data from filer volume to your drive.
