ONTAP Hardware
RBAC on NetApp controller
1VINAYKUMAR
Hi Techies,
I have a task assigned to create a RBAC on NetApp storage controllers (FASXXX, AFF-A300, etc) for our L2 and L3 team members. can anybody help me here with understand what are the roles that we can assign to L2 and L3 team members.
Thanks in advance.
regards
Vinay
1 REPLY 1
donny_lang
Vinay,
There are several pre-defined roles for cluster administrators, one of which may fit your needs. They are detailed here:
https://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.pow-adm-auth-rbac%2FGUID-62DD97C5-8907-4A5A-9773-591721CE6B9F.html
If one of the pre-defined roles isn't a fit, you may want to review the ONTAP 9 Administrator Authentication and RBAC Power Guide at https://library.netapp.com/ecm/ecm_download_file/ECMLP2496262 to understand ONTAP's capabilities for defining custom roles that make sense for the L2 and L3 team members in your organization.
Hope that helps!
Donny
