ONTAP Hardware
Reallocate 800GB LUN with Snapshots
andreas_koeller
Hi Folks,
i want to reallocate a LUN in our FAS3020 SAN.
The lun is 800GB big.
What about the alleady existing Snapshots after the reallocate?
How big will be the next Snapshot after reallocateing the lun?
Can i do the reallocate step by step? i.e. 10 Minutes Reallocate then stop an the next day go on?
Which command should i use for reallocating the lun?
Regards,
Andreas
2 REPLIES 2
radek_kubka
Hi and welcome to the forums
Short answer - have a look at reallocate manual on http://now.netapp.com/NOW/knowledge/docs/ontap/rel732_vs/html/ontap/cmdref/man1/na_reallocate.1.htm. The actual switch you should be looking at is -p:
Using the -p option may reduce the extra storage requirements in a flexible volume when reallocation is run on a volume with snapshots. It may also reduce the amount of data that needs to be transmitted by SnapMirror on its next update after reallocation is performed on a SnapMirror source volume.
Long answer - type "reallocate" in search box here on communities & go through the results. This thread is absolutely priceless in my opinion & gives you tons of information:
http://communities.netapp.com/message/20969#20969
Another one, nice example from the field about the practical impact of fragmentation & reallocation:
http://communities.netapp.com/thread/7456
Hope it helps.
Regards,
Radek
peluso
Thanks radek for responding!
I moved this thread to the product & Solutions area within the community to give expand the visibilty for the question.
Terri
Thanks so much!
Terri Peluso
Senior Community Program Manager
