ONTAP Hardware
Replace CPU AFF A200
Sycon1976
I have an A200 in my home lab that the controller on side A will not power on.  I am able to get to the BMC and look at the event logs and it appears the CPU is having issues.
I removed the controller and heatsink, but it looks like the CPU is soldered directly on the motherboard.  Can anyone confirm that is the case?
1 ACCEPTED SOLUTION
chamfer
The AFFA200 (and FAS2600) are fitted with the Intel Xeon-D 1528 Processor, which is a FCBGA1667 SoC (System on Chip), which are soldered directly on motherboards.
https://ark.intel.com/content/www/us/en/ark/products/91198/intel-xeon-processor-d-1528-9m-cache-1-90-ghz.html
2 REPLIES 2
chamfer
Sycon1976
Thank you, exactly what I needed to know.
