ONTAP Hardware
Replace FAS2040 controller module
CityofLA
Received replacement controller which has CF card, the only instructions I have is the original "Hardware Overview of the FAS2040 System' that came with the system. I have an active/active config, with node already taken over. Is there a clear step by step set of instructions? Do I only place the CF card from old controller to new? Should the battery and DIMMS be moved over to the new controller also?
2 REPLIES 2
NAYABSK
Hello,
Thank you for reaching NetApp community. Yes you need to move the NVMEM battery and DIMM from the old controllers to the new.
Find the document attached for reference.
Reference :- Replacing a controller module in a 20xx system
Thanks,
Nayab
LeeNorman
Do you have a parts list and diagram/s for the FAS2040?
