ONTAP Hardware
Replace Filer
NKUNETAPP
Where can i find documenation on replacing a filer with a newer one, I have a FA3140 I am replacing with a FA3240.
I am new to the site and I know the answer should be around here somewhere but I havent found it yet.
1 ACCEPTED SOLUTION
ralfaro01zero
You can find information on NOW site, I found this:
http://now.netapp.com/NOW/knowledge/docs/hardware/NetApp/cs_migration/FAS31xx/31xx_to_62xx_single-controller/GUID-BE903B5F-F52B-45DD-BDF1-B012704E6C12...
This is the upgrade guide for a FAS31xx to a FAS62xx, I don't think there's much difference, someone correct me if I'm wrong please.
Cheers.
3 REPLIES 3
ralfaro01zero
Cheers.
avalonzst
Can you post the content in your replay, because some can not access this kbs page. Thanks
Renifa
Hi,
Try the following link.
https://library.netapp.com/ecmdocs/ECMP1140577/html/GUID-6C3427B1-F6EA-4143-9579-FEF88B8D5842.html
Thanks,
Renifa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
