ONTAP Hardware
Replacing the HD drive.
ssmbugach
I need to buy discs 600GB 15K RPM SAS for NetApp DS4243. How can I do this?
4 REPLIES 4
cedric_renauld
Hi, Serge,
Have you a NetApp Partner ?
Normally the easy way is to contact the Partner who have sold to you the controler
Or consult the NetApp web page of your country
ssmbugach
Hi, Cedric,
Partner is trying to sell me a shelf with disks.
He says that I can not buy separately drives. If the GPL have drives separately and you know the item part number, tell me this number, please.
I asked on the local NetApp site , but there was no answer.
cedric_renauld
So, your partner will be able to sell you some disks without shefl ...
try this ref :
X412A-R5
ralfaro01zero
I assume you are not trying to mix different disk technologies on the same shelf, if so, you do need a new shelf.
Cheers.
