ONTAP Hardware
[SOLVE] Wrong spare disk used as a data disk
laniocedric
Hello,
I've got a issue with my disk on a FAS2020, I explain:
I've got 2 type of physical disk in the system : 413 GB and 827 GB. Before the problem, there was 1 spare disk of each type.
One of my 413 GB disk failed and instead of the 413 GB spare disk, the system use a 827 GB spare disk as data disk for the agregate.
So now I've got 2 413 GB spare disks and no 827 GB spare, and one 827 GB disk use as a 413 GB data disk.
Is there a way to move a 413 GB spare disk as data and obtain the return of my 827 GB data disk as a spare ?
You can see the problem on this screenshot - disk involve is the 0c.00.6
Thank you for your help ! 🙂
1 ACCEPTED SOLUTION
SYNTAXERROR
Have you tried to replace it:
"disk replace start 0c.00.6 0c.00.0"
to replace the bigger one with the spare.
Use the option -m if it don't works like this.
3 REPLIES 3
SYNTAXERROR
laniocedric
Looks like it is the perfect command, thank you !
I pass it and comme back for the result.
Thanks again for your support ! Smiley Very Happy
laniocedric
It works perfectly ! Smiley Very Happy
Thank you SyntaxError for this solution !
