ONTAP Hardware
SSD X357A-R6 add
codeleexise
Hello,
I came to X357 because of the wrong order.
Originally, I should have ordered X356.
The equipment uses fas8020 ontap 8.2.3P3.
The DS2246 was equipped with the X357 and zeroing was completed.
If I add Aggr in this state, it won't be applied, right?
1 ACCEPTED SOLUTION
andris
You wanted X356A.
SSD, 3.8TB, SAS
You accidentally ordered X357A.
SSD, 3.8TB, SAS, MSW
If you review the HWU information, you will see that X357A is not supported on FAS8020 or ONTAP 8.2.x 7-Mode.  You will need to order X356A.
1 REPLY 1
andris
You wanted X356A.
SSD, 3.8TB, SAS
