ONTAP Hardware
Supported SFP modules for FAS2720
A_Zhurenkov
Hello. I want to connect FAS2720 to C9300 and trying to find supported SPF modules but I can't get access to HWU. Could someone send me this information?
1 ACCEPTED SOLUTION
darb0505
Hi @A_Zhurenkov ,
I have attached a PDF that includes all the cable and SFP for the onboard ports.  I would recommend opening a support ticket to get access to the HWU and NetApp support site.
Thanks
Team NetApp
6 REPLIES 6
darb0505
Hi @A_Zhurenkov ,
Are you wanting to know the supported SFP for the FAS2720 or for the C93000?  Are you going to be running at 1 or 10 Gbps ?
Thanks
Team NetApp
A_Zhurenkov
Hi, @darb0505
I want to know supported 10G modules for FAS2720.
darb0505
Hi @A_Zhurenkov ,
The supported 10G SFP module would be part number: X6589-R6.
Team NetApp
A_Zhurenkov
Hi @darb0505,
Could you send me information about all supported modules for FAS2720? I want to know about 16G FC modules and maybe samething else later.
darb0505
Hi @A_Zhurenkov ,
Thanks
Team NetApp
A_Zhurenkov
Hi @darb0505 ,
Thank you so much!
