ONTAP Hardware
Transceivers SFP+ 10G Compatibility
Davidoo
Hello
How to determine if a SFP+ 10G is compatible with a FAS ?
Thanks a lot ..
1 ACCEPTED SOLUTION
JPick
Hello.  This information should be in Hardware Universe (https://hwu.netapp.com/).  Depending on the FAS model, and whether you are using the SFP onboard or in an adapter card, you can search for both the NetApp and Manufacturing SFP part numbers either in the "Supported Adapter Cards" or "Onboard Ports & Cables" links for the FAS in question.   I hope this helps.
2 REPLIES 2
JPick
andris
If Hardware Universe doesn't have what you're looking for, another supplementary information source is this KB article:
How to determine the NetApp part number for Brocade and NetApp SFPs
