ONTAP Hardware
Two SVM one FAS
Sebagari
Hello, I have a FAS2520 with Ontap 9.3 with one (1) SVM running with iSCSI and CIFs.
I want to create a second SVM only for iSCSI, how do I configure the network connection?
do they share the ethernet ports?
some document that explains how to implement multiple SVM?
Thank you.
2 REPLIES 2
Sebagari
The idea is to replicate each SVM to a FAS2220 for backup with snapmirror. In total there are 3 FAS, one FAS2520 with all the information and 2 FAS2220 backup. The idea is to distribute the backup information between both FAS2220.
Sebagari
Hello,
I was able to create new lif via CLI using ethernet port ok.
thanks.
