ONTAP Hardware
USB port on FAS/AFF 8000?
aborzenkov
Any chance to use it for software/firmware updates with ONTAP 9?
5 REPLIES 5
andris
I'm pretty sure the USB support for "system node firmware download", i.e. -package file://usb0/<filename> is only available with the current-generation FAS/AFF hardware platforms - not the FAS/AFF80x0. But hey... give it a shot and prove me wrong 🙂
AlexDawson
From the documentation I have reviewed, it should be impossible in all public release builds.
If you find a way to do it, please submit a BURT 🙂
wbrock
Does anyone have link to documenation that show the functions of using the USB on the controller.
andris
There's a release note item and more details in the respective man pages of the related commands.
Support for installing ONTAP software and firmware from an external USB mass storage device
For hardware models initially supported by ONTAP 9.1, you can install the ONTAP software and firmware from an external USB mass storage device. With this enhancement, the external USB port on hardware platforms installs or copies ONTAP software and firmware on the embedded boot media.
The USB device is specified as file://usb0/filename. For example, the file name can be image.tgz. The ONTAP software and firmware installation package must be present in the root directory of the USB mass storage device.
The following commands access the ONTAP software and firmware installation package from the external USB mass storage device:
  • system node image get
  • system node image update
  • system node firmware download
  • storage firmware download
Note: The commands system node firmware download and storage firmware download are available to cluster administrators at the advanced privilege level.
AlexDawson
And for all older systems, you can use it (unsupported) to charge your iPhone, plug in a USB light, or power your serial to bluetooth/wifi device
