ONTAP Hardware
Unchecking background deduplication have an adverse impact?
Bravo7555
Running a FAS250 SAN connected to a VMWare enviornment. My volumes are thick provisioned and are showing 0 bytes of available space. I am not using snapshots however dedupe is enabled on the volumes. To try and see if i can reclaim space, i was going to uncheck background deduplication on each volume. Any thoughts surrounding this? If I uncheck this will it impact the volumes in a negative way?
These are all in production and cant afford to make any mistakes.
3 REPLIES 3
SpindleNinja
Read up on what dedup is.  https://www.netapp.com/us/info/what-is-data-deduplication.aspx
Disabling it isn't disruptive,  but i think it'll do the opposite of what you're trying to fix.
Do you have free space on your aggrs?    can you grow the volumes?
Sebastian_Goetze
Well, you said SAN, so I'm assuming you have VMFS datastores in LUNs in the volume(s)?
And taking a wild guess: They're not thin provisioned either ("space reserve")?
Then you will not "see" the effect of the deduplication within the volume(s)!
You can however see the effect at the aggregate level, e.g. "storage aggregate show-efficiency".
If you want to see the savings at the volume level, you'll have to thin provision the LUNs:
"lun modify -space-reserve disabled"
No adverse effects as far as I can see, since you said, you're not using snapshots (which could use up the space within the volume).
dedupe pro:
  • more physical space in the aggregate (not necessarily logical, depends on if the volumes are thin provisioned or not)
  • more performance (higher probability for cache hits, more free blocks for writes)
dedupe con:
  • less performance (see above)
  • impact on controller while dedupe is running (do it during off-hours)
In contrast to your plans, I'd even evaluate, if you can switch on "inline-dedupe".
It's opportunistic, i.e. only executed if it doesn't get in the way of your primary workload.
It takes load off your backend if it succeeds, since then only pointers have to be written instead of also data blocks.
Depends on the overall utilization of your system, though. But generally speaking with a virtualization workload it should improve your performance, even with a small system like yours (provided you don't have stupid things in your VMDKs like mis-alignment or databases - which generally don't dedupe at all)
Hope that helps
Sebastian
chenguanghui
hello:
  By default, for files with reserved space or LUNs configured with thick provisioning, the reserved percentage will be enabled to create snapshots and overwrite. Disabling deduplication will not cause any interference to the system. If there is space on the aggregate, it is recommended that you increase the capacity.
Hope it helps.
Best regards.
