ONTAP Hardware
Upgrade FAS 270 Ontap, not the default way ?
YAMAKASI_D
Hi All,
I'm trying to update an old FAS270 for some tests to 7.3.6 as I have figured out this must be the latest version for this device.
The docs lack here a little bit as it's unclear how to update this device:
netapp-01> software update http://192.168.1.100/736_sysfiles_m.tar
software: You can cancel this operation by hitting Ctrl-C in the next 6 seconds.
software: Depending on system load, it may take many minutes
software: to complete this operation. Until it finishes, you will
software: not be able to use the console.
software: copying to 736_sysfiles_m.tar
software: 100% file read from location.
software: /etc/software/736_sysfiles_m.tar has been copied.
software: installing software, this could take a few minutes...
ziperr: /etc/software/736_sysfiles_m.tar: Unable to locate end-of-central-directory record
software: Error unzipping /etc/software/736_sysfiles_m.tar.
software: installation of 736_sysfiles_m.tar was not successful.
netapp-01> Sat Apr 26 10:19:44 GMT [rc:info]: software: installation of 736_sysfiles_m.tar was not successful.
Is anyone able to give some advice on this ?
Thank you
2 REPLIES 2
YAMAKASI_D
OK, solved with some other worksarounds... the actual way you should do on a 270.
skjusto
If anyone ends up running into this issue in the future...the solution is you need to install from the .exe image, not the .tar image.
