ONTAP Hardware
Used FAS3140 factory reset
BogdanOp
I bought a used FAS3140 from someone and I realized that I do not have the serial number and I cannot find it on the case so I can register the product on the site. Also i don't have a username and password to be able to login via ssh ... Does anyone know how i can reset it to the factory settings
2 REPLIES 2
andris
wareer
1. Access the console of both controllers through a serial connection
At startup, press Ctrl-C to access the startup menu
Shut down all nodes (this can be done by shutting down the chassis PSU or uninstalling the controller), and then restart
From the startup menu, select option (4) : Clean configuration and initialize all disks
Clear all configurations and data and reconfigure the device
2. If you want to keep the previous configuration, only change the current password:
Console access to both controllers via serial connection
Shut down a node (this can be done by shutting down the chassis PSU or uninstalling the controller) and then restart
Select option (3) from the startup menu: Change password.
Enter your user name, and then enter a new password
You will be returned to the startup menu. Select option (1) for normal boot
Below is the official operation link of the specific operation, you can refer to:
https://kb-cn.netapp.com/on-prem/ontap/Ontap_OS/OS-KBs/How_to_reset_admin_password_from_boot_menu_in_ONTAP
