ONTAP Hardware
VIF with one interface?
tvmo_tvmo
Can I create a VIF with only one interface?
This VIF with be one of two VIFs contained in a second-level VIF configuration. Each of the VIFS will contain one port at the moment I'm intending on adding more ports at a later stage.
Thanks
1 ACCEPTED SOLUTION
reinoud7
A vif with one interface is no problem. Than you can add, when you want,  very easy a second interface.
Reinoud
2 REPLIES 2
reinoud7
Reinoud
tvmo_tvmo
Thanks Reinoud
