ONTAP Hardware
VPN Filter Malware
npotts001
Hi everyone,
Has there been any offical statement to confirm if NetApp is vulnerable to the VPN Filter Malware which we know affects Cisco and Qnap routers.
More information can be found here & here
Kind Regards
N Potts
1 REPLY 1
AlexDawson
Hi there,
There is nothing in anything I've seen to suggest NetApp devices might be vulnerable to this, no. Initial information suggests it is only an issue for NAS systems from another company. ONTAP does not share code from this platform.
The initial information (in your linked posts) suggest this is installed by exploiting default credentials, which are generally not present on NetApp systems, and directly connected to the internet, which NetApp systems are not commonly.
