ONTAP Hardware
Verify Shelf Cabling
dtrujillo63
Does the cabling below look correct? This is a FAS2240-2 with a DS4243 Shelf.
1 ACCEPTED SOLUTION
SeanHatfield
Its laid out pretty clearly in the setup poster for that platform:
https://library.netapp.com/ecm/ecm_get_file/ECMP1149275
Or just follow the diagrams at the top of this thread.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
15 REPLIES 15
CCOLEMAN_
Very close!
Left Controller Square > Top Shelf Module Square
Right Controller Square > Bottom Shelf Module Square
Left Controller Circle > Bottom Shelf Module Circle (flipped)
Right Controller Circle > Top Shelf Module Circle (flipped)
You flipped the end of the stack perfectly, but the way you cabled it would mess you up when you need to hot add a shelf.
ACP looks perfect.
dtrujillo63
Are you sure? According to the documentation, circles are connected to squares and squares are connected to circles.
ogra
Correct the Circle <-> Square relationship needs to be maintained.
BDANDRUS
Did this ever get answered?
I have inherited the same setup but I'm pretty sure it is cabled incorrectly.
AGUMADAVALLI
Run the config advisor or wire gauge to find the health of your HA pair. That will give complete answer.
You will not be able to download the config-advisor or wire gauge, please engage the Professional Services or NetApp.
thank you
aK G
BDANDRUS
Um yes I can:
http://support.netapp.com/NOW/download/tools/config_advisor/
Not sure that will help though. Seems odd that nobody can just look at the picture and say yes or no...
o.O
Brian
AGUMADAVALLI
Run the config advisor, it will help no doubt. You will also get a detailed report too what is bad in the environment.
thank you
AK G
ogra
Hi Brian,
Can you please provide more details which diagram are you referring at ?
Cheers!
@bakshana
BDANDRUS
The first one that is a photo with the red and blue lines.
mcgue
The bottom diagram of page 36 has the answer - https://library.netapp.com/ecm/ecm_get_file/ECMM1280392
The only difference is that you only have one disk shelf instead of a stack.  Your first picture matches the SAS cables per the diagram in the PDF.
Also run the config advisor, it is always a good tool to run to cross check and verify.
Take care,
Tim
ogra
Hi Brian,
Yes that's correct.
There are 2 factors for doing the SAS cabling :
1) Square goes into Circle
2) Last 2 Ports of the Stack are attached to the controller in reverse order. ( If you have a single disk in the stack you simply reverse it there only).
Hope it helps!
matthes138
Im looking for SAS cabling of a FAS2220 with 2 controllers to a single DS2246-R5
Any documentation/diagrams to help me understand the best practice for cabling shelf’s
SeanHatfield
ratnarajah29
Hi  dtrujillo63
Is there a link to draw the diagram as shared? Thanks in adv
Fabian1993
Hi @ratnarajah29
you can simply use VISIO and the Shapes from http://www.visiocafe.com/netapp.htm, to build the Diagram with your Hardware.
