ONTAP Hardware
Viewing Battery from RLM
alexander7
Hello All!
Is there a way to see the NVRAM battery state from the RLM of a FAS3140?
Thank you if you answer
5 REPLIES 5
scottgelb
I don't know of a command on rlm (there may be something to list sensors, but not sure on nvram), but I would "system console" to get to the console, login to the controller, then "sysconfig -a" and "environment status" to see NVRAM... even better, setup an alert with ops manager and make sure autosupport is enabled which will send an alert if the battery is low.
alexander7
Thank you Scott!
What if Data ONTAP is not loaded because of some failure?
BrendonHiggins
It is my experience the RLM is the same as having a serial cable plugged into the filers serial port.  If the filer is dead and will not power on, the rlm access will not help.  Get around this problem by asking a local 3rd party to connect a serial cable to a local machine and using Windows RDP or other remote control product to access the console session on this machine.  This assumes the filer can be made to try and start by the 3rd party.
If the filer will power on and the RLM is correctly configured but DoT will not boot.  You should be able to connect to the RLM and then connect to the filer system console.  You should then be able to bounce the filer while the RLM continues to report what is happening.  Interrupt boot process to access the special boot menu and run diagnostics.  Either full system or just on the NVRAM system, just select from menu.
Hope it helps and good luck with the recovery.
Bren
NetApp Diag
http://now.netapp.com/NOW/knowledge/docs/hardware/NetApp/diag/html/ch1/booting.htm
NVRAM error codes
http://now.netapp.com/NOW/knowledge/docs/hardware/NetApp/diag/html/ch3/ch3a/nv7_env.htm
balaji65
Hi Alexander,
Was a solution found to this problem.were u able to view the battery from the RLM::
alexander7
Our battery was not charged when we got our FAS3140. In some time after, it was charged enough, we could load Data ONTAP and monitor the battery through Data ONTAP. It looked OK, so we stopped trying to see the battery from the RLM.
