ONTAP Hardware
What does HA meaning for for disk?
DavidCao
Netapp enginner replaced a disk 11b.17.2 for us. But new disk is 1a.17.2. Is this a problem for it? Why is it not same with the old name? What does HA mean in a disk name? Thanks.
If the disk is not zeroed, how to handle it? Thanks.
By the way, it is FAS3240.
1 REPLY 1
aborzenkov
Yes, it is normal. Disks normally have two paths and it does not matter which path is used to address it. Use "disk zero spares" to zero it.
