ONTAP Hardware
What is the aggr usable capacity for FAS9000
ShivaR
Hi,
Can anybody have an idea what would be the usable space for root aggregate for FAS9000 with 3 disks. Actually it is varying from synergy report.
And also i have a difference in data aggregate usbale space also from synergy and my system,
Aggregate     Size Available Used% State   #Vols  Nodes
aggr1 119.1TB 119.1TB 0% online  0 node-01   raid_dp,
root 1.40TB 69.37GB 95% online   1 node-01   raid_dp,
synergy report: - attached
root aggr usable : 1.61 TB
data aggr usable: 130.98 TB
Why is this differnce, I suspect synergy has a bug.
Can anybody calculare manually.
Write capacity of disk is 1.63TB
Thanks in advance!
1 ACCEPTED SOLUTION
AFlowers
Synergy is calculating space using Base 2 while the FAS9000 is calculating space using Base 10.  TiB vs TB
You can toggle this in Synergy under settings.
Explanation here:  http://www.diskview.com/disk-size-discrepancy.htm
1 REPLY 1
AFlowers
