ONTAP Hardware
X477 Disk is displayed at 15000 rpm on the fas3240
wuijolskd
Hello
When I put Ownership in a new X477 that does not contain Ownership, the 7.2K disk appears to be 15K.
Is there a way to check technical documents related to this phenomenon?
1 ACCEPTED SOLUTION
wuijolskd
That situation has been resolved by replacing it with another disk.
We will also proceed with DQP updates and Disk Firmware updates.
Thank you.
5 REPLIES 5
pedro_rocha
Hello,
Can you post some outputs?
Regards,
Pedro
wuijolskd
Hello
Here is the requested data.
A photo showing the part number and serial number of the disk '3c.22.9' used, a scene using the command 'sysconfig -r', and 'log' data.
Thank you.
AlexDawson
What is the date code of the DQP file?
rdfile /etc/qual_devices_v3 and it's at the bottom (and top)
andris
Alex's DQP info request is important...
Nice uptime...
What is the ONTAP version?
X477_TTCRE04TA07 latest firmware is NA03 - highly recommend update, too.
wuijolskd
Thank you.
