ONTAP Hardware
cDOT and 32 bit volumes
1netapp4me
We are looking to transition into a cDOT cluster on 8.2 and then 8.3 when released. What command can i run to easily see whiWe are looking to transition into a cDOT cluster on 8.2 and then 8.3 when released. What command can i run to easily see which volumes are still 32 bit and then how do I convert them to 64 bit? Is that handled at the aggregate level?<br>Thanks!ch volumes are still 32 bit and then how do I convert them to 64 bit? Is that handled at the aggregate level?<br>Thanks!
1 ACCEPTED SOLUTION
keithpjolley
Check out Technical Report 3978 - In Place Exansion of 32-bit Aggregates to 64-bit.
1 REPLY 1
keithpjolley
