ONTAP Hardware
change
kapral516
I have one disk
Part Number
Product Description
E-X4132A
DSK DRV,12TB,7.2k,12Gb,Non-FDE,DE460C
What is the Alternative to it with the same parameters and to work with netapp
Since i am new in netapp storage
Please help
Regards
Dmitry
1 ACCEPTED SOLUTION
SpindleNinja
You will need a matching part #.  You cannot take an off the shelf drive and put it in.
Do you have a support account on this system?
1 REPLY 1
SpindleNinja
