ONTAP Hardware
cluster management lif is not at home port
backupstorageCRM
Hello Team,
We had manually moved LIF cluster_mgmt from not working port ( S1D1NNFBKP8020-01_mgmt1 10.189.187.170) to working port (S1D1NNFBKP8020-02_mgmt1 10.189.187.171) to access storage and performed down/up port on S1D1NNFBKP001 port e0M for troubleshooting purpose
Fri Jun 24 09:48:42 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF cluster_mgmt (on virtual server 4294967295), IP address 10.189.187.174, is being removed from node S1D1NNFBKP001, port e0M.
Fri Jun 24 09:48:42 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifmoved.byadmin:notice]: LIF cluster_mgmt (on virtual server 4294967295), IP address 10.189.187.174, is being moved to node S1D1NNFBKP002, port e0M.
Fri Jun 24 09:52:46 IST [S1D1NNFBKP001: vifmgr: vifmgr.portdown:notice]: A link down event was received on node S1D1NNFBKP001, port e0M.
Fri Jun 24 09:52:46 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifdown.noports:alert]: LIF S1D1NNFBKP8020-01_mgmt1 (on virtual server 4294967295), IP address 10.189.187.170, currently cannot be hosted on node S1D1NNFBKP001, port e0M, or any of its failover targets, and is being marked as down.
Fri Jun 24 09:52:46 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF S1D1NNFBKP8020-01_mgmt1 (on virtual server 4294967295), IP address 10.189.187.170, is being removed from node S1D1NNFBKP001, port e0M.
Fri Jun 24 09:53:05 IST [S1D1NNFBKP001: vifmgr: vifmgr.portup:notice]: A link up event was received on node S1D1NNFBKP001, port e0M.
Fri Jun 24 09:53:05 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifbeinghosted:notice]: LIF S1D1NNFBKP8020-01_mgmt1 (on virtual server 4294967295), IP address 10.189.187.170, previously marked as down, is now up and serving data on node S1D1NNFBKP001, port e0M.
Fri Jun 24 09:53:05 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifsuccessfullymoved:notice]: LIF S1D1NNFBKP8020-01_mgmt1 (on virtual server 4294967295), IP address 10.189.187.170, is now hosted on node S1D1NNFBKP001, port e0M.
Fri Jun 24 10:50:08 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF S1D1NNFBKP8020-01_mgmt1 (on virtual server 4294967295), IP address 10.189.187.170, is being removed from node S1D1NNFBKP001, port e0M.
Fri Jun 24 10:51:05 IST [S1D1NNFBKP001: vifmgr: vifmgr.lifsuccessfullymoved:notice]: LIF S1D1NNFBKP8020-01_mgmt1 (on virtual server 4294967295), IP address 10.189.187.170, is now hosted on node S1D1NNFBKP001, port e0M.
As now we are trying to check at hardware aspect but i need to know how to get check lif availability before migrating to home port and what can be reason for more history refer case 2009217608 , anymore suggestion to bring up the lif back to normalize until then we will check the hardware aspect
2 REPLIES 2
NetApp_SR
The node management LIF and SP use e0m so you can attempt to ping or connect to those IP addresses.
weiliu
1. Run the network interface failover-groups show command to view your failover group and check whether the e0m of the node has a proper failover group.
"network interface failover-groups show "
2, you can use the following command to return your port to the master node.
“network interface revert -vserver vserver_name -lif lif_name”
