ONTAP Hardware
cluster switch login issue
Fuad
We are getting the following error while trying to login to our cn1610 cluster switch:
You cannot visit xxx.xxx.xxx.xx right now because its certificate has been revoked. Network errors and attacks are usually temporary, so this page will probably work later
1 ACCEPTED SOLUTION
andris
In fact, the CN1610 does not support any form of web interface. If you are trying to reach it with HTTP or HTTPS, it should fail.  The only supported remote login methods are SSH and Telnet (if enabled).
2 REPLIES 2
AlexDawson
Login via SSH? or to the web interface?
If it's the web interface, the obvious option is that an enterprise PKI certificate has been installed and that certificate has been revoked by your enterprise PKI administrator and your browser has been configured to not allow access to SSL sites with revoked certificates. Click the (broken?) padlock in the address bar of your browser to investigate the certificate chain it is supplying.
andris
