ONTAP Hardware
csm.sessionFailed
sed_streaming
Hi All,
we have a FAS8040 running Ontap 9.1.
On Oncommand System Manager in Events tab we have this error:
Event:
csm.sessionFailed: Cluster interconnect session (req=dmpp-storage-01:dblade, rsp=dmpp-storage-01:dblade, uniquifier=110548029cbc24fa) failed with record state ACTIVE and error CSM_CONNABORTED.
Message Name:
csm.sessionFailed
Sequence Number:
2363819
Description:
An existing session between one appliance and another appliance failed because packets are not reaching the other appliance.
Action:
If you can reach the storage failover (SFO) partner of the target appliance, initiate a storage failover (takeover) of any aggregates on the target appliance. Then perform a 'sendhome' operation on these aggregates after the target appliance is operational again. Examine the network between the initiating appliance and the target appliance for problems.
Anyone knows hot to solve it.
All the appliance are online so the reccomended action is really not a solution.
1 ACCEPTED SOLUTION
Sahana
Hi,
It could be due to the bug: http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=987327
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
3 REPLIES 3
Sahana
Hi,
K_Schwarz
Hello,
we have created a case at NetApp because of the excat same error-
We were referred to this bug:
https://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=1060720
ptroy
Upgrade to 9.1.P9
Cheers
