ONTAP Hardware
disk config question 2040c ds4243 shelf
oweinmann
Hi,
we now have our new and fancy storage system here. I was going to configure it as follows and Im not sure wether this is good or not.
The ds2040c has 12 x SAS 600GB
The ds4243 has 24 x 1TB
I would like to configure as follows:
filer1:
aggr0 5 disks / 1 Spare
aggr1 11 disks / 1 Spare
filer2:
This is the config since max Raidgroup size for SATA disks with Raid-DP is still 16.
Cheers,
1 REPLY 1
henrypan1
I'd configed a similar filer few weeks ago which is running fine so far:>)
Each of my AGGR with 16 disks ( Either 600 SAS or 1 TB SATA)
Good luck
Henry
