ONTAP Hardware
failover takeover issue
Jaypi
I was trying to takeover the other node but the state description says that Takeover is not possible: Local node missing partner disks?
SFO is already enabled and all the connection to both nodes are good!
Thanks!
3 REPLIES 3
naveens17
What version of ONTAP your running
Check the bug :
1007467
Jaypi
NetApp Release 9.1P8
naveens17
Thanks.
can you check sktrace logs to see if the mail box disks are responding very slowly..?
