ONTAP Hardware
fas-2020 re-setup from scratch
RICARTE2014
Hi,
I have a decommissioned FAS-2020, i want to re-setup the storage, (new ip, new luns). for test purpose.
i want to know how to go about it, i don't see any reset button .
anybody can guide me.
pls help.
thanks
1 REPLY 1
francoisbnc
if the idea is to initialize all from scratch
- Connect through BMC.
- Switch in console mode.
- Reboot, During boot press ctrl-C
- Clean configuration and initialize all disks.
Regards,
François
LOADER-A> boot_ontap
Loading x86_64/freebsd/image1/kernel:.....0x100000/8455008 0x910360/1278312 Entry at 0x80158990
Loading x86_64/freebsd/image1/platform.ko:.0xa49000/655152 0xb97c40/694752 0xae8f40/39656 0xc41620/43152 0xaf2a28/86316 0xb07b54/63858 0xb174e0/140640 0xc4beb0/159120 0xb39a40/2024 0xc72c40/6072 0xb3a228/304 0xc743f8/912 0xb3a358/1680 0xc74788/5040 0xb3a9e8/960 0xc75b38/2880 0xb3ada8/184 0xc76678/552 0xb3ae60/448 0xb6f000/12918 0xb97b53/237 0xb72278/84120 0xb86b10/69699
Starting program at 0x80158990
NetApp Data ONTAP 8.1.4P1 7-Mode
Copyright (C) 1992-2014 NetApp.
All rights reserved.
md1.uzip: 25536 x 16384 blocks
md2.uzip: 5760 x 16384 blocks
* Press Ctrl-C for Boot Menu. *
^CBoot Menu will be available.
Please choose one of the following:
(1) Normal Boot.
(2) Boot without /etc/rc.
(3) Change password.
(4) Clean configuration and initialize all disks.
(5) Maintenance mode boot.
(6) Update flash from backup config.
(7) Install new software first.
(8) Reboot node.
