ONTAP Hardware
fas2520 single controller direct connect to Vmware Esxi 5.5
ANTONIO_SIMULA
Dear it's possible to connect directly (with out switch) the fas2520 via isci 10G port to the server Esxi ?
the fas2520 is a single controller in 7-mode 8.2
Vmware esxi version is 5.5u2
thanks
Antonio
1 ACCEPTED SOLUTION
ANTONIO_SIMULA
Thanks forma you replay 🙂
2 REPLIES 2
HONIG2012
yes in 7-mode this is possible to a max. of 4 hosts (filer has 4x10GbE Base-T)
-AJ
ANTONIO_SIMULA
