ONTAP Hardware
fcp start: Partner WWNN must match local WWNN to start FCP
josso02
NetApp Release 7.3.6P2 (FAS3020c)
I'm having trouble starting the FCP. It says "fcp start: Partner WWNN must match local WWNN to start FCP".
This system used to be a cluster but has been decommissioned recently and moved to PreProd environment. There's only one Disk shelf (DS14MK2 FC) connected to the controller (Stand-alone)
Here's the current setup:
*>fcadmin config
Local
Adapter Type State Status
0a initiator CONFIGURED. online
0b initiator CONFIGURED online
0c target CONFIGURED offline
0d target CONFIGURED offline
0a is connected to ESH Module A
0b is connected to ESH Module B
0c is connected to a SAN Fabric
0d is connected to a SAN Fabric
I entered into "Special Boot Menu" and chose "4a" to initialize the entire system but still it didn't let me start the FCP. I even tried changing the "nodename", after adding the FCP license (KB ID: 2013604)  I tried with the below config too,
Nothing made a difference. Any suggestions?
I can't follow KB ID: 2010727, as I don't have access to the partner controller anymore.
https://library.netapp.com/ecmdocs/ECMM1278252/html/cluster/failing_over/task/t_oc_fo_mng-unconfig-hw.html#t_oc_fo_mng-unconfig-hw - This didn't work either.
1 ACCEPTED SOLUTION
georgevj
That means the system still thinks that its part of an HA pair. 😞
What does the following command command say?
controller> fcp show cfmode
is it saying
fcp show cfmode: System is not clustered. Unable to show cfmode.
or
is it still showing "single_image" ?
Also, please make sure that the NVRAM card is in slot #1, not in slot#3.
You may check this with the command: (last character is the  number one)
controller> sysconfig -a 1
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
9 REPLIES 9
georgevj
could you try the following?
FAS3020> halt
once halted, from CFE prompt;
CFE> set-defaults
CFE> unsetenv partner-sysid
CFE> boot_ontap
and after booting up,
what is the output of "cf status" command?
josso02
I was able to run commands in CFE prompt and after booting up, here's what the "cf status" says,
Cluster must be licensed and the system rebooted before using this command.
*>fcp start
fcp start: Partner WWNN must match local WWNN to start FCP under Single Image
georgevj
is it saying
or
aborzenkov
It also could be stale LUN configuration options.  KB 1013497  lists some steps to reset configuration.
georgevj
JOSSO02 had re-initialized the system, (option 4a from boot menu), so I assume no stale LUNs.
@aborzenkov , thanks for the KB, its good information.
aborzenkov
Right. In this case it most probably NVRAM slot.
josso02
Are we expecting a below output from sysconfig -a 1? The below output is from another stand-alone production system.
*> sysconfig -a 1
slot 1: NVRAM (NetApp NVRAM V)
Revision: B1
Serial Number: 534607
Memory Size: 512 MB
Battery Status: OK (4032 mV)
Charger Status: OFF
Running Firmware: 7 (3.5.0)
Cluster Interconnect Port 1: disconnected
Cluster Interconnect Port 2: disconnected
memory mapped I/O base 0xa1800000, size 0x100000
prefetchable memory base 0xa1000000, size 0x800000
prefetchable memory base 0x80000000, size 0x20000000
*> sysconfig -a 3
sysconfig: No such slot 3
georgevj
yes , this is what is required for standalone system.
josso02
Moving the NVRAM back to Slot 1 did the trick. Thanks guys for your precius time and sharing your knowledge. It was much appreciated.
> fcp show cfmode
> sysconfig -a 1
Revision: B1
Serial Number: 542735
Memory Size: 512 MB
Charger Status: OFF
> sysconfig -a 3
slot 3: Quad 10/100/1000 Ethernet Controller VII
e3a MAC Address: 00:1b:21:12:ad:f0 (auto-unknown-cfg_down)
e3b MAC Address: 00:1b:21:12:ad:f1 (auto-unknown-cfg_down)
e3c MAC Address: 00:1b:21:12:ad:f2 (auto-unknown-cfg_down)
e3d MAC Address: 00:1b:21:12:ad:f3 (auto-unknown-cfg_down)
Device Type: Rev 3, PBA D30273-005
memory mapped I/O base 0xa0540000, size 0x20000
memory mapped I/O base 0xa0500000, size 0x40000
I/O base 0x0000efc0, size 0x40
memory mapped I/O base 0xa0560000, size 0x20000
I/O base 0x0000ef40, size 0x40
memory mapped I/O base 0xa0580000, size 0x20000
I/O base 0x0000ef80, size 0x40
memory mapped I/O base 0xa05a0000, size 0x20000
I/O base 0x0000ef00, size 0x40
> fcp status
FCP service is running.
> fcadmin config
Local
0c target CONFIGURED online
0d target CONFIGURED online
