ONTAP Hardware
i
Ogojoseph
Hello All,
I have just newly attached a new ESH4 to ESH2 on FAS 980C Netapps. I tried to check it to see if the filer head can see it but it was not successful.
What can I do to make sure the file head can see the added disk shelf.
Emmanuel
1 REPLY 1
artur_kusiak
You need to make sure that your shelf ID's are set correctly and that the ESH4 shelf is set to 2Gbs for the loop.
Thank you
Artur
