ONTAP Hardware
info message after resizing vol0 - perf.archive.max_disk_space.changed
markfrickle
So I resized my vol0 down from 522G to 500G on all my filers, and I got this on one of them:
Tue Jun 22 08:33:25 PDT [filer2: perf.archive.max_disk_space.changed:info]:
Maximum disk space consumption allowed for the performance archiver was
changed from '14422869361' to '10737418241' bytes. Change not committed.
Is there any way to set Performance Archiver's max disk space consumption or is this a hard setting in the system?
1 ACCEPTED SOLUTION
Darkstar
It's a hidden registry option:
filer*> priv set diag; registry walk stats
stats.archive.max_disk_space_percent=2
-Michael
8 REPLIES 8
aborzenkov
I believe it should be option stats.archive.max_disk_space_percent.
markfrickle
filer1> options stats
No such option stats
Darkstar
-Michael
markfrickle
That was the answer, Thanks Michael.
aborzenkov
filer1> options stats.archive.max_disk_space_percent
stats.archive.max_disk_space_percent 2
markfrickle
You are correct, sorry I must've fat fingered the first time I tried it.
Anyway, I think it resolved itself because the stats directory on that filer has since shrunk.
cairoldes
Hi! I had the same message from our FAS3240 when resize the root volume:
perf.archive.max_disk_space.changed:info]: Maximum disk space consumption allowed for the performance archiver was changed from '7112916829' to '565127332' bytes. Change not committed.
What is the performance archiver ? and Which can change with this setting ?
Any recomendations ?
Thanks
aborzenkov
NetApp collects detailed performance stats (with second resolution) by default. This is large amount of data so it will automatically delete older stats when consumed space exceeds threshold. Threshold is computed as percentage of root volume size which explains why it changes when root volume is resized.
There is KB article about performance archiver, I do not remember exact number.
